1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I bought this truck last fall. It’s a 78 D100 cab on an 83 W150 chassis. The cab and box sit 1 1/4” low on the left side. What causes this and what’s the best way to correct it?
Ok, I’ll check that. I’m heading to the US tomorrow for a week, then home for a couple days and gone again for three or four so it’ll likely be a couple weeks before I get back at this.
@Hey You the frame at the very rear is about the same off the floor. At the front of the rear spring mount it’s about 1/2” higher on the high side of the truck. Sounds weird right? At the front the frame is about 3/8” higher on the high side. Both front leaf springs have four leaves. On the rear the high side has 6 and the low side has 7. The box and cab seem to be in good alignment with each other as seen in the last picture.
Can I just add a 1” spacer to the front and rear mounts to level it out. I realize this will effect the shock length but the truck will get very few miles each year and likely only on paved roads.
