Won't Start After Getting to Operating Temp
Old 09-17-2022, 11:25 AM
TheaMo67's Avatar
TheaMo67
TheaMo67 is offline
Alright guys, thanks for your suggestions. I've discovered it's the coil after doing a volts and resistance check. It's putting out 4 volts, and no resistance from either side post to the center, where the wire goes to the distributor.
Old 09-17-2022, 12:13 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,257 Likes on 3,004 Posts
Yep, that's bad.
Old 09-17-2022, 09:20 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
Thinkin' maybe vapor lock?
well considering ethanol evaporates at 172*F and the engine usually runs at 195*F. it is a pretty common issue with carbs with smaller float bowls to have the fuel evaporate which is why some people recommend spaces for carbs like edelbrock. i never had issues with holley but float bowls on them are pretty big. i do usually run enthanol free fuel in all my carbed vehicles. costs a bit more but worth in in my opinion. i used to be able to leave my truck at work for 10 hours and be able to turn the key and have it start like i just left it.
are you sure your checking it right? i would assume if it is at least running when cold it should still get good when cold. did you disconnect it before testing? i would say if it was bad no voltage at all would be going through it.
Quick Reply: Won't Start After Getting to Operating Temp
