Fuel pump replacement
Hey all, working on a fuel pump replacement here. Got my old pump out, as you can see there’s a void on my new one where I assume I’m supposed to swap that vent thing onto it. Can’t seem to figure out how to remove it from the pump though. Would appreciate some help.
Okay I’ll try that quick thank you. I was trying to pull it out from up top but it sounded like it was cracking so I stopped lol. Do you know what the part is called in case I break it? Are new ones even available anywhere?
Okay I got it out and the grommet is actually in decent condition. Next hard part is getting it back through the new fuel pump lol. Is there any kind of lubricant I could put on the rubber to make this easier that won’t be bad if it gets in the gas tank?
Edit for anyone else doing the job; I used petroleum jelly on the gasket for lubrication, popped it off the rollover valve and pushed it into the hole on its own and then pressed the valve back into the gasket. Apparently the rollover valve isn’t available for sale anymore if you break them so thankfully I didn’t have that issue. If you do, pick a part seems to be the best bet. I’ve also seen plastic welders online recently, I wonder if those would be usable for those of you that did break them. Someone should try and do a write up if they get decent results.
for future reference it is usually easier and cheaper to just replace the pump and strainer. you can replace it them for about $30-40. only reason i would consider replacing a whole assembly is if you needed a new fuel lever sensor. some get glitchy with age. friends truck drops to empty when between 1/8 and 1/4 tank but the truck also has over 500k on it.
By the way, since I got the truck a year or two ago it’s had a strong gas smell to it. I’ve seen some people talking about it in other threads about the gas tank, is there a known cause/fix for that? Kinda like to get it taken care of as well while I’m in there if I can.
Trending Topics
I checked rockauto after I bought the pump through autozone unfortunately. It all worked out though, like I said the new sending unit will be nice too.
The fuel smell could’ve been caused by a small crack in the fuel line that ended up blowing out, I’m not sure. My initial assumption was that it was because my exhaust had rotted off right after the cat but as I was looking through forums I saw a few other people mention a similar smell. Thought there might be a known issue that caused these trucks to reek of gas. Doesn’t really bother me either way but I get a lot of comments about it lol
i just find a lot of the time rockauto is much cheaper than the local auto parts store but you also generally end up having to wait a couple days to receive stuff. i have likely saved thousands over the years ordering from them especially if you get the parts dirt cheap on clearance.
a leaking fuel line will definitely cause a smell.
