1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The battery is always charged up really good when this happens and yes they click without the engine running until I turn off the switch. But this is the first time that I couldn't get spark from the coil.
No, I don't have a scanner. The problem now is that it won't start. I mean without it running, it won't go into the misfiring mode. The only time all the injectors click is when it starts misfiring and then stalls. It makes no sense to me. Could a bad ignition coil cause the problem? Like I said...the coil won't fire now. Can I test the coil with a ohm meter and if I can, how would I go about doing that? What should the readings be. I really can't afford the process of elimination. I thank you for helping me.
Well I went out there a little bit ago and tried it and it started but it will not rev up and it's popping through the pipes really bad. Could it be the crank sensor or maybe the computer?
