Voltage Jumps
Old Jan 23, 2023 | 10:30 PM
JXTNSADVNTR's Avatar
JXTNSADVNTR
Default Voltage Jumps
1993 W150, 5.9l 360 Magnum
So, I've noticed a weird issue with my truck this last week. While driving, my volt gauge will randomly drop almost all the way down, (to the first dash after the 8, I think 9 or 10), I believe this is an altimeter issue, however I was hoping that I could get some other input on other possible problems. I plan on checking the alternator later this week. What are the odds of it being a bad battery or a possible computer issue?
Old Jan 24, 2023 | 08:55 AM
Altimeter? What altitude do you generally drive at? (posting from a phone by any chance?? )
Voltage regulator is in the PCM, you can pull the alternator, and have it tested, if it passes..... may wanna investigate the external regulator fix.
Old Jan 24, 2023 | 04:39 PM
JXTNSADVNTR
Ha, I was definitely posting on my phone last night... but around 5,800 - 6,000 ft. lol
Anyways, I got the alternator tested today, and it may be a bad voltage regulator in the computer, but as it was still hooked up to the truck at the time I'm going to pull it off and get it tested again. I also plan on checking all of my fusible links that tie into the power system and computer. I'm new to an older dodge, so I have a fair bit of learning on it's systems, diagnosis, and repairs. Hopefully it's not a computer issue.
Old Jan 24, 2023 | 05:28 PM
And he has a sense of humor! We're gonna like this one.
Get the alt tested, let us know the results.
Old Jan 25, 2023 | 11:01 PM
JXTNSADVNTR
So, I finally got around to working on my truck after work today; and I discovered that my B+ terminal cable at the slip ring had burned up. Not only that but it had gotten hot enough that it welded the slip ring, nut, and stud together which then snapped off. All together, I'm replacing the alternator, and most likely going to have to replace the alternators wiring harness. It's nice to know what's wrong, but I'm not exactly happy about it. Do y'all think that it's likely this burned up the PCM as well? I did check the wires, and the burned portion only went back around 3 inches. I may be able to salvage this wiring harness, but I won't know until friday when I have some more experienced help. (My dad)
EDIT *Fixed some of the Terminology*
