1988 dodge d150 318 with tbi bogging and backfire
Old 02-05-2023, 06:32 PM
Justatruck's Avatar
Justatruck
Justatruck is offline
Coil maybe
Old 02-05-2023, 06:49 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,274 Likes on 3,021 Posts
Entirely possible. Check spark when it's hot, and hard to start. See what it looks like.
Old 02-05-2023, 06:51 PM
Justatruck's Avatar
Justatruck
I'll probably go out and get new coil try it see what happens
Old 02-06-2023, 02:04 PM
Justatruck's Avatar
Justatruck
Put new coil on but nothing changed I was going to check vacuum on fpr and it has none is that normal at idle ? And there is a flap on my manifold when I open it it sounds better in gear and at idle and it doesn't move unless u manually move it should it be open or closed seems like that would cuase back pressure
Old 02-06-2023, 02:22 PM
HeyYou is offline
I don't know if that is ported, or manifold vacuum on the regulator..... Try cracking the throttle with your finger... or a gauge, on it, see if anything happens.
Pic of the flap??
Old 03-24-2023, 12:55 AM
88bigblue's Avatar
88bigblue
88bigblue is offline
I had a simular problem. Intermittent Bad distributor. Replace whole distributor, problem went away.
Old 03-24-2023, 06:40 AM
Moparite's Avatar
Moparite
Moparite is offline
Your first problem is this...
A period is a small dot-shaped punctuation mark that is used at the end of any sentence that is intended to make a statement.
I had to read your first post 3 time to figure out what you are trying to say. I would put a pressure gauge on it and see if you are getting a steady fuel pressure. Also does it make any difference if the engine is hot or cold? Does a 88 have a temp gauge?
Old 03-26-2023, 12:12 AM
Trajan3's Avatar
Trajan3
Trajan3 is offline
Mine did same thing and it was a a couple of times over the years it was always a bad EGR valve.
Quick Reply: 1988 dodge d150 318 with tbi bogging and backfire
