No.check.engine.light no start
No.check engine light no fuel pump relay working. Relay was getting hot and shutting truck down. Now I have no check engine.light, fuel.pump.relay won't work, have jumped.wirw for pump and turns on have swapped relays, and tested fusable links coming off battery starter turns over, just replaced computer, now I'm stumped cleaned.grounds and.put.new.ends on at ac motor block area. Now I'm stumped
i used a multimeter I see no volts.
