High Park/Neutral Idle
Old Jul 19, 2023 | 05:56 PM
Ray Wilson's Avatar
Ray Wilson
maybe. if you give it gas does it return like it should? i would almost wonder if you may have been having issues with choke linkage. the choke will usually hold the throttle open some till the choke fully opens and you give it gas and it starts using the idle stop.
Yes, it returns like it should. I’ve moved it through P R N D several times and it idles and shifts properly. The choke not moving much does concern me though… it’s warm now but it can get pretty cold up here in the winter.
Old Jul 19, 2023 | 06:05 PM
crazzywolfie's Avatar
crazzywolfie
i would try unplugging the wire to the choke thermostat and maybe see if it is getting constant power even when the truck is off. must be some reason for it to not return unless it is the wrong choke thermostat since it does look newer.
Old Jul 19, 2023 | 06:12 PM
Ray Wilson's Avatar
Ray Wilson
Please tell me this is the choke thermostat. If I’m wrong then I’ve learned nothing in all the reading I’ve done.
Old Jul 19, 2023 | 06:35 PM
crazzywolfie
lol yes that is the choke thermostat.
Old Jul 19, 2023 | 06:46 PM
Ray Wilson's Avatar
Ray Wilson
Finally I’m making progress lol. I disconnected it from power. I guess I’ll let it sit and see what happens.
Old Jul 20, 2023 | 09:14 AM
Ray Wilson's Avatar
Ray Wilson
After a whole night of sitting and cooling with the coil unplugged, the choke was nearly fully open. I’m thinking about removing the coil to examine it. It looks pretty old judging by the power cable.
Old Jul 20, 2023 | 12:25 PM
crazzywolfie
did you press the gas to reset it? it can not return to the closed position without you hitting the gas which is part of why you are supposed to pump the gas a couple time when starting a cold carbed engine.
Old Jul 20, 2023 | 12:33 PM
Ray Wilson's Avatar
Ray Wilson
Certainly did. I just went back outside to look at it and it looks like it’s closed a bit more.
Old Jul 20, 2023 | 12:36 PM
crazzywolfie
ok just making sure. definitely seems like there is so something wrong with the choke thermostat if it will not close the choke. can you manually close the choke when you hold the throttle open?
Old Jul 20, 2023 | 12:39 PM
Ray Wilson's Avatar
Ray Wilson
About this far holding the throttle wide open. Looks about the same as the previous picture.
