Low Voltage at Wiper Motor
Old Jul 14, 2023 | 10:07 PM
Ray Wilson's Avatar
Ray Wilson
Ok, switch is fed via fuse 6 (20a) in the junction block in the cab. (fuse box.) It will be the dark blue wire at the back of the wiper switch. Hot in accessory, or Run.
Thanks, I’ll give it a check in the morning!
Old Jul 14, 2023 | 10:14 PM
Let us know what ya find.
Old Jul 15, 2023 | 01:44 AM
Ray Wilson's Avatar
Ray Wilson
I was cruising through the forums and found this about the wiper motor:
the wiper motors on these are grounded through the bolts and it is very common for them to just all of a sudden quit working. it would be best to try running a jumper wire from a good ground connection to the wiper motor body. i think i have seen some people bolt a ground wire to one of the wiper motor bolts and run it to the body somewhere close by
Grounded through the bolts that hold the wiper motor onto the mounting bracket!? I feel like I’m losing my mind ​​​​​​​
Old Jul 15, 2023 | 08:54 AM
Gotta ground somewhere. But, if you were testing voltage to a known good ground, and weren't getting much, don't worry about the ground side of things just yet.
Old Jul 15, 2023 | 10:41 AM
Ray Wilson's Avatar
Ray Wilson
Alright, I solved the voltage issue and I’m getting proper volts. I got everything mounted up and STILL didn’t work. Took it off and I grounded it from the screw to the negative battery terminal and it works fine.
I bought a length of wire, some ring terminals, and fashioned up a proper ground wire. I connected it to the screw holding the windshield washer fluid outlet (name?) in place. It works!
Anyone see a problem with that? Thanks for the input.
Old Jul 15, 2023 | 12:35 PM
If it works as it should, then there is no problem.
Old Jul 15, 2023 | 01:29 PM
Ray Wilson's Avatar
Ray Wilson
It finally works…. Thank you! Hopefully others will see this post and learn from all of my errors.
