Low Voltage at Wiper Motor
Old Jul 14, 2023 | 08:14 PM
Ray Wilson's Avatar
Ray Wilson
Default Low Voltage at Wiper Motor
I purchased a new wiper motor and tested it, it works!
BUT it doesn’t work when I connect it to the connector…. I’m getting low voltage at the wiper motor connector (see photo). At least I think it’s low voltage. Not sure what it should be, but it’s not enough to power the motor.
Perhaps the contacts in the connector have corroded over the years? Any advice?
Low voltage on High setting. No voltage on Lo or Delay.
Old Jul 14, 2023 | 08:49 PM
Set your meter on 20 volts DC, re-test.
Old Jul 14, 2023 | 08:50 PM
Ray Wilson's Avatar
Ray Wilson
Old Jul 14, 2023 | 08:52 PM
See if you have power coming in to the switch.
Old Jul 14, 2023 | 09:05 PM
Ray Wilson's Avatar
Ray Wilson
How do I check that? I’m a 99% newbie with electrical. I barely taught myself to use the multimeter. I thought it was quite an accomplishment I was able to test the voltage at the connector lol!
Old Jul 14, 2023 | 09:50 PM
What are you driving?
Old Jul 14, 2023 | 09:51 PM
Ray Wilson's Avatar
Ray Wilson
‘87 D150 318. I thought I put that in my signature, sorry.
Old Jul 14, 2023 | 09:59 PM
Too obvious.
Do you have delay wipers? Or just the two speed?
Old Jul 14, 2023 | 10:00 PM
Ray Wilson's Avatar
Ray Wilson
Too obvious.
Yes, I have Delay, Lo, and Hi.
Old Jul 14, 2023 | 10:04 PM
Ok, switch is fed via fuse 6 (20a) in the junction block in the cab. (fuse box.) It will be the dark blue wire at the back of the wiper switch. Hot in accessory, or Run.
