Electrical problems 1987 dodge d100
Old Jan 17, 2025 | 09:08 PM
CashMan123's Avatar
CashMan123
Default Electrical problems 1987 dodge d100
1987 dodge d100 with no click no start. Clean truck with 40000 miles but all of the sudden I went out from running an errand and have no clicking at the relay when trying to start. I jumped the terminals at the starter to get home. I replaced the ignition switch wiring and have the same issue. I have also replaced the starter relay and same scenario. Battery terminals got cleaned and wires are in good shape. I wired in a push button temporarily so I could drive and that is when I noticed the ac fan won’t turn on as well as the cabin light. Blue wire on ignition is getting 12 volts when key "on" but I cant get 12 volts on the yellow when turning fully to engage the starter. Any thoughts? Thanks in advance.
Old Jan 18, 2025 | 03:29 AM
Moparite's Avatar
Moparite
Have you checked the neutral safety switch?
Old Jan 18, 2025 | 01:13 PM
CashMan123's Avatar
CashMan123
Not yet but it will start in neutral with the push to start so I thought no need to check it. Would I be wrong?
Old Jan 18, 2025 | 01:32 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by CashMan123
1987 dodge d100 with no click no start. Clean truck with 40000 miles but all of the sudden I went out from running an errand and have no clicking at the relay when trying to start. I jumped the terminals at the starter to get home and it’s fine. I replaced the ignition switch; same issue. I have also replaced ed starter relay and same scenario. Battery terminals got cleaned and wires are in good shape. Also the ac fan won’t turn on as well as the cabin light. Any thoughts? Thanks in advance
Did you check both ends of the cables? I'm thinking you may have a problem with the ignition switch, but I check the cables first anyway. The kay cylinder should pull a rod down to the switch which is usually on the steering column.
Old Jan 18, 2025 | 06:12 PM
CashMan123's Avatar
CashMan123
Yes I did, everything points to the ignition switch but I have tested it and it seems to be fine. "The kay cylinder should pull a rod down to the switch which is usually on the steering column." Can you explain this better please I am having trouble understanding this.
Old Jan 18, 2025 | 06:15 PM
Basically, the switch isn't exactly close to the key cylinder. When you turn the key, it pushes a rod on the side/bottom of the column, that actually pushes the switch, which is further down. (at least, on the tilt columns.....) If you pull the knee panel, that hides all that stuff, it'll be obvious.
Old Jan 18, 2025 | 06:22 PM
CashMan123's Avatar
CashMan123
What are you referring to as the knee panel? It isn't a tilt column.
Old Jan 18, 2025 | 06:29 PM
May still use the same style system, Don't know on that though. I haven't worked on anything that old in quite some time.
Old Jan 18, 2025 | 06:44 PM
ol' grouch's Avatar
ol' grouch
Pull the power panel off the dash under the steering column. About halfway down the column you'll find a bunch of wires going to the actual switch.
https://www.ebay.com/itm/17416319150...Bk9SR7rFtbyPZQ
The key cylinder is more of a steering lock. It also works the ignition switch via a rod going down to it. Sometimes those go bad or you have a problem with the wires there.
