Tie Rod Help
Old Mar 15, 2025 | 02:58 PM
Dinkleburg238's Avatar
Dinkleburg238
Not having a brace shouldn't matter. No clue why things are so out of whack though. If the frame shop said the frame was straight, and not tweaked in some manner...... Anyones guess what is really going on there.
Take one of your tie rods to the hardware store, get a nut that will thread onto it. (that might be a problem for the left-hand threads though, I doubt you'll find a nut for that one....) Twist the nut on till the amount you want to cut off is sticking out, hack it off with some manner of saw/cut-off wheel, then take the nut off. That will kinda/sorta correct the threads The other one, you will likely need to dress it with a small file.
Thanks for the method suggestion, was just sitting here wondering how I was going to do this without botching the threads lol
Old Mar 15, 2025 | 08:12 PM
Keep in mind, those are hardened steel. So, have several saw blades/cutoff wheels handy.
Old Mar 15, 2025 | 09:28 PM
Dinkleburg238
Surprisingly I got through both and the adjustment sleeve with half of one of harbor freights finest death wheels lol. Realized to get more adjustment I needed to cut the adjustment sleeve too since the tie rods bottom out on stock lengths, but was able to get it all back together with now another 1/2" adjustment, hopefully it's enough whenever I can get it back to the alignment shop.
Thanks for the help
Old Mar 15, 2025 | 09:34 PM
Well, that was easier than I thought it was gonna be.
Congrats.
