My Lowered 90 Ram
Old Mar 18, 2006 | 05:15 PM
Rampant 150's Avatar
Rampant 150
Default RE: My Lowered 90 Ram
Do you guys know how I can properly lower my 93 d150 (no cutting or heating springs). Im just looking for a mild drop so that it is still usefull.
Old Mar 20, 2006 | 12:54 AM
outlaws318's Avatar
outlaws318
Yeah, lowering shackles from Ground Force
Old Mar 20, 2006 | 04:03 AM
Rampant 150
Yeah, lowering shackles are easy enough to find, but try to get drop spindles or lowering kits for the front of a 93 ram.
Old Mar 21, 2006 | 01:16 AM
outlaws318's Avatar
outlaws318
I've been to almost every company, and can't find anything. Try find lowering springs from another truck that would fit it. This weekend I'm lowering my truck. Right now I have the 2" shackle drop from Ground Force. That was $50.00 and I got the flip kit for the rear. That was $35.00 at Jeg's from Mopar. I'm just going to heat the springs for now. That's what I did on my Mazda MX-6 and it had a great ride to it. I'll put pictures of before and after.
Old Mar 24, 2006 | 11:19 PM
Pat Delaney's Avatar
Pat Delaney
HOLY CRAP!!! 1990???
How many engines have you had to put in that thing?
... or has it been stored since it was new?
Old Mar 25, 2006 | 12:12 AM
horatio102's Avatar
horatio102
Pat - these engines will easily go 150-200k with normal service, longer if exceptionally well cared for. My 86 is on its second motor at 260k and it's running really strong, but I suspect it's getting time for a quality engine build. The last one was an autoparts store special long block about 90k ago, and it's smoking a bit on startup.
Old Mar 31, 2006 | 04:00 AM
outlaws318's Avatar
outlaws318
I finalgot my truck lower over the weekend, it was some what of a pain in my ***, but I got it done. I have pictures of it, but it want let me put them on here.
Old Mar 31, 2006 | 04:20 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
ORIGINAL: outlaws318
email them to me at Twistedillusions24@yahoo.com. I'll gladly resize them for you and post them up, or you could create a photo gallery and then you could upload them to that.
You can create a gallery Here
Gallery photo sizes can be larger and arent restricted like the pictures are in posts.
Old Apr 25, 2006 | 02:28 AM
Rampant 150
To those still intersted in this.
Aim industries sell drop coils and lowering a-arms for early rams. The web site is www.truckin.com. If anyone has tried these out, let me know.
Old Apr 26, 2006 | 12:39 AM
outlaws318's Avatar
outlaws318
Alright, I've got my truck lowered. Flip kit on the rear end with 2" lowering shackles, and heated the front spring. With the rear don't use lowering shackles with it. It drops the axle right on to the frame. Not good. The flip was pretty easy if you have somewhere and all the tools. You'll have to make a custom barcket for the shocks, I'm still working on how to make the whole setup better. Heating the front springs wasn't the best way of lowering the front, but it was the cheapest and easiest. The part for the rear end to lower cost $12.99 from Jeg's, Part # 312-P4120074...Spring Perch. I'll tell you more as it goes. Right now I'm redoing to rear axle because the carrier pin broke and broke the teeth on the gears. This is why you should make sure the sup. is tight before you take it to the track. I'm tring to find 3.90 gears.
