Lifting a Ramcharger
Old Feb 25, 2006 | 01:45 AM
jaxjeff's Avatar
jaxjeff
Default Lifting a Ramcharger
I was curious if anyone has tried to lift a ramcharger?
My dodge is a 92 ramcharger, 2wd. It is a very clean truck and i don't want to trade it for a 4x4 truck. Does anyone have any suggestions or know anyone who has done a lift? Also someone said the front end was similar to a dodge pickup 2wd of the same year.
Please let me know your suggestions!
thanks
Jeff
Jacksonville FL
Old Mar 1, 2006 | 10:22 PM
Quiefinator's Avatar
Quiefinator
Default RE: Lifting a Ramcharger
more info would be nice
1st, why???
2nd Function? looks, prerunner, wheeling?
3rd what kind of front end suspension setup
the rear will be easy as hell
although i dont know much about your model, i have done quite a bit w/ lifting 4x4's, so since no one has posted u back i could at least get u in the right direction if i knew what kind of front end u have, coils, leafs, etc. pics maybe
Old Mar 1, 2006 | 11:56 PM
joschmo86's Avatar
joschmo86
I have an 85 Ram D150, and I will be lifting it soon as I get the transmission fixed. Its a 2WD, so I am keeping it simple and using leveling kit(coil spacers) for the front. Daystar makes some, I dont know for our trucks but I did this to my 93 Isuzu before. For the rear you can either do shackles, blocks between the axle and leaf spring(and longer u-bolts), or go more "custom" for actual suspension improvement.
I am going for just a better stance/offroad look. Kinda pre-runner daily driver, and 32" tires will fill the wheel well enough to make it look good. Also, the suspension parts are similar for the same year Rams/Ram Chargers, as long as you stick with 2wd and v8. GOOD LUCK
Old Mar 2, 2006 | 12:31 AM
DodgeRam318_4bbl's Avatar
DodgeRam318_4bbl
My dream is to find an 81-84 Ramcharger with a 440 V8, stick shift, and 4WD and massively lift the sucker (at least 12 inch suspension and 2 inch body lift) and add 33" tires and a Warn winch on the front. Also a Dixie horn is a must with both an American flag and a Confederate flag flying off the back.
Old Apr 2, 2006 | 07:33 AM
dannyac's Avatar
dannyac
I have an 84 RamCharger with the 360, lifted 10", riding on 36" buckshot mudders. Got a rebel flag, too.
I'll let you borrow it
Old Apr 3, 2006 | 02:47 AM
DodgeRam318_4bbl
Stick or auto? (Please be stick, Please be stick, Please be stick. [&:])
