light issue
Old Mar 4, 2006 | 09:32 PM
powerram1985's Avatar
powerram1985
Default light issue
my 87 has roll bars on it with lights on the top... for some reason only one light works, i replace the bulb and then flip the switch, and one of the lights blows, but the other works, is it possible that i need thicker gauge wire? what would be a recomended course of action?
Old Mar 20, 2006 | 04:13 AM
Rampant 150's Avatar
Rampant 150
Default RE: light issue
Usually when bulbs or fuses blow its because of improper wiring or shorts in the system. Test you wiring with a test light to make sure that everything is hooked up right, and look for worn out wires touching any metal surface.
