over/under 4000
Old Apr 23, 2006 | 11:03 PM
charlie1935's Avatar
charlie1935
Default RE: over/under 4000
Another thought. Was it built in Canada? That be kilograms GVWR.
Old Apr 23, 2006 | 11:38 PM
savage_racing's Avatar
savage_racing
so is there away to break the vin down or???
if gvwr was in kilos that would be around the 2000lb mark
is there a straight answer to this question
Old Apr 24, 2006 | 12:08 AM
charlie1935
Over two pounds per kilogram. I'm sure there is a way to break down the VIN, but I don't know it. Sorry i ain't more help.
Old Apr 24, 2006 | 12:18 AM
savage_racing
yeah sorry wrong way 10760lb
no problem, anyone else got an answer
Old Apr 24, 2006 | 02:53 PM
horatio102's Avatar
horatio102
A 3/4 ton first gen Ram will have a gross vehicle weight in the 8000 pound range. A heavy duty 3/4 ton will have a gross weight of about 8510 pounds. A 1-ton should be closer to the 10k pound gross weight.
4670 lbs could be your tare weight - empty. I know that's about what my W250 weighs, but that's not a gross weight at all. Off the top of my head I don't know what my individual axle gross weights are.
Old Dec 19, 2022 | 12:51 PM
RAMJAMVAN's Avatar
RAMJAMVAN
Hello all, I have a 02 Ram Van 2500 CNG in need of front ball joints.
GAWR tag shows 3880 front. Does this indicate 4000lb axle? VIN doesn't work in any of the sites to run build sheet. 284JB25T62K124219
I'm aware this is a pickup thread, but there's far more traffic there than the van forums where I also asked
Thanks very much!
Old Dec 19, 2022 | 06:04 PM
u2slow's Avatar
u2slow
I can't speak for the van, but 3 of my D250 Cummins pickups have 3800# gawr on the front, and it's all 4000# stuff.
Old Dec 19, 2022 | 09:51 PM
crazzywolfie's Avatar
crazzywolfie
you should double check that vin. change that 8 to a B and the build sheet pops right up but won't really help
https://www.chrysler.com/webselfserv...JB25T62K124219
Old Dec 20, 2022 | 01:09 AM
RAMJAMVAN's Avatar
RAMJAMVAN
FARK!!! That's what VIN was sent to me without access to the vehicle, now looking at the placard you're very much right.
Thanks very much for all the help to you both. I've ordered both sets and will return the unused pair.
