Not getting any fire to the dist.....HELP
Old Sep 25, 2009 | 09:38 PM
  #31
1987PowerRam150318's Avatar
1987PowerRam150318
Will that keep my coil from sparking even though the coil wire isn't hooked up?
Old Sep 25, 2009 | 10:50 PM
  #32
charlie1935's Avatar
charlie1935
The reluctor triggers the spark by turning through the magnetic field.
If the gap is not right I believe it could result in a weak or possibly no spark.
I am not an expert on this, but just tyring to figure it out long distance.
Old Sep 25, 2009 | 11:07 PM
  #33
1987PowerRam150318
Sure, and I appreciate the help. I will double check that first thing in the morning and report back my findings.
Old Sep 26, 2009 | 02:13 PM
  #34
crazzywolfie's Avatar
crazzywolfie
http://www.classicspark.com/English%...system-uk.html
Old Sep 27, 2009 | 08:15 PM
  #35
1987PowerRam150318
That worked, now the damn thing just don't wanna start!
Old Sep 27, 2009 | 09:01 PM
  #36
crazzywolfie
put a bit of gas down each cylinder.
Old Sep 27, 2009 | 10:17 PM
  #37
1987PowerRam150318
You mean pull each plug and put some gas into each that way? About how much should I put? If that doesn't work, what should my next step be? Thanks for all y'alls help.
Old Sep 27, 2009 | 10:24 PM
  #38
crazzywolfie
ya that is what i meant but i just thought of this. you should try pouring some gas down the carb first.
Old Sep 27, 2009 | 11:14 PM
  #39
1987PowerRam150318
I'll double check tomorrow but I think the carb is filling the bowl. Everything was running perfectly, by there was a chunk of the distributor that I could not retrieve from wherever it gets stabbed. I tried starting fluid today but no dice. The fuel filter and EGR valve have both been replaced. I did notice today that the choke vaccuum is plugged or cut, can't really tell. I'll report back tomorrow!
Old Sep 28, 2009 | 04:23 PM
  #40
1987PowerRam150318
Ok well the starter died. Replaced it and nothing. Going to replace the rotor and quintuple check the reluctor gap and there should definitely be enough spark to get that fire a burnin'.
