2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
MyGIG Mods / Hacks?
Old Mar 31, 2008 | 09:37 AM
  #41
TheDeak08's Avatar
TheDeak08
Default RE: MyGIG Mods / Hacks?
So has anyone had any success ghosting the hard drive image to a larger drive? I'm interested in doing this cause I just can't fit all my music on the so called 30 but you can use 17GB hard drive.
Old Apr 8, 2008 | 01:17 AM
  #42
ano's Avatar
ano
I have partial success. I make copy of Mygig drive by Norton Ghost to the larger hard drive, but cant resize partitions. Mygig work with the new drive, but the size of partitions is the same
Old Apr 8, 2008 | 09:42 PM
  #43
futil's Avatar
futil
Did you try Acronis True image and Acronis disk Director? Acronis tends to be more versatile than Norton products.. Plus it doesn't write any data to the original disk when making duplications.
http://thepiratebay.org/ There are a few reliable copies here..
I would try it myself but I don't feel like pulling my radio again.. but the next time I have to pull it I will try it if you don't get to it..
Old Apr 27, 2008 | 11:03 PM
  #44
nonrev's Avatar
nonrev
Have you exported the nav data yet? It exports to a CVA file and it looks like it has the address book info in it. Anyone know how to edit the data? It would be nice to be able to load the address book that way rather from the screen.
Vernon
Old May 1, 2008 | 12:30 PM
  #45
dnjtwigg's Avatar
dnjtwigg
Junior Member
1)While in park, bring up the DVD and start watching the movie.
2)Push the AUDIO button, that will bring up the balance adjust menu
3)Put the vehicle in drive and start driving
4)Push DONE on the audio screen That should revert right to the movie instead of the standard mygig menu
****NOTE**** Subsequent DVD function or touching the screen will revert back to mygig screen but if you leave it alone it should play smoothly
DRIVE RESPONSIBLY!!
If you still have problems go to this link...
http://www.youtube.com/watch?v=aDBxxjP_XZc
That is a video to show you how to do it (in case your missing something)
Old May 1, 2008 | 12:32 PM
  #46
dnjtwigg's Avatar
dnjtwigg
Junior Member
DRIVE RESPONSIBLY!!
Old May 13, 2008 | 12:23 AM
  #47
archerr23's Avatar
archerr23
Hi,
I just tried the method dnjtwigg described on my avenger sxt, but it didn't work, did everything exactly as described, just wondering if anyone else could watch their dvd while in drive? Thanks for any info.
Old Aug 17, 2008 | 06:38 PM
  #48
albertaavenger's Avatar
albertaavenger
just to let you all know i successfully increased mygig hard drive to 120gb
Old Aug 22, 2008 | 02:39 PM
  #49
TedEbear's Avatar
TedEbear
You must have a lot of music files. I have all mine loaded and I've used less than 4GB.
Old Aug 26, 2008 | 02:01 PM
  #50
Namrac's Avatar
Namrac
Junior Member
Default How
How did you do it
