2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Brake light goes on and off
Old Jan 26, 2008 | 12:10 PM
SueK's Avatar
SueK
Default RE: Brake light goes on and off
ORIGINAL: fenderman
Sue,
You can take your car to ANY dodge dealer. They cannot tell you to go somewhere else. Its part of every francise contract.
Thanks very much!
Old Jan 26, 2008 | 03:04 PM
pbearfin's Avatar
pbearfin
Mine did the samething at about 17k It was just low brake fluid.
Old Jan 27, 2008 | 03:53 AM
ryandun06's Avatar
ryandun06
well im not sure about the 08 but the same sorta thing happened to my 03 except the light stayed on. Water had gotten into the plug that connects to the abs box under the hood. All i did was unplug it and blow out the plug with the air compressor to dry it out and it worked fine after that. On my truck the box is located on the drivers side closest to the cab. Give it a try!
Old Jan 27, 2008 | 12:26 PM
SueK's Avatar
SueK
ORIGINAL: ryandun06
Did it just come on when coming to a stop going down hill ? Thanks for the tip.
Old Jan 27, 2008 | 12:27 PM
SueK's Avatar
SueK
ORIGINAL: pbearfin
My fluid is fine and it only comes on when I'm stopping downhill. Then it goes off when I'm level again.
