2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Check Eng. light
Old Jul 6, 2009 | 12:18 PM
RAMcCon1's Avatar
RAMcCon1
Default Check Eng. light
Does anyone know how to access the on board diagnostic system to show the codes on the dash display on my 2008 Avenger 2.4L 4cyl?
Old Jul 13, 2009 | 04:53 PM
mrrbby's Avatar
mrrbby
Go buy an engine scanner from your local parts store. Mine was around $130, and works on all my vehicles (96 and up). The good ones will give you the codes, and tell you in plain english what they mean.
Old Jul 24, 2009 | 02:36 AM
Crashaholic's Avatar
Crashaholic
This is from memory... I think its right...
Turn your ignition key from the off to the ACC position three times in and in place of the odometer will cycle the codes... Use your favorite search engine to lookup the code.
