2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Brake Min thinkness
Old Oct 15, 2010 | 11:11 AM
mark2494's Avatar
mark2494
Default Brake Min thinkness
Hi,
New here to the fourm. I have a 2008 Dodge Avenger SXT with 38,000 miles. I need to replace the front brakes, I am wondering if anybody knows the min thickness of the rotors or knows where I may be able to find it? With onyl 38 K I should be able to turn them. Right??
Thanks!!!
Old Oct 15, 2010 | 12:38 PM
mark2494's Avatar
mark2494
I have a follow up question.
1) If I needed to could I use pads from NAPA and rotors from another mfg, or do they need to match? Ie Napa pads, Napa Rotors?
Old Nov 17, 2010 | 12:36 AM
master tech's Avatar
master tech
Site Moderator & Tech
SPECIFICATIONS
NOTE: When refacing a rotor, the required TIR (Total Indicator Reading) and thickness variation limits MUST BE MAINTAINED.
Braking Rotor Rotor Thickness Minimum Rotor Thickness Rotor Thickness Variation Rotor Runout*
Front Rotor 25.90–26.10 mm 24.40 mm 0.005 mm 0.05 mm
(1.020–1.028 in.) (0.961 in.) (0.0002 in.) (0.002 in.)
Rear Rotor – 14-inch** 9.80–10.20 mm 8.40 mm 0.015 mm 0.06 mm
(0.386–0.402 in.) (0.331 in.) (0.0006 in.) (0.0024 in.)
Rear Rotor – 16-inch*** 9.80–10.20 mm 8.40 mm 0.015 mm 0.04 mm
(0.386–0.402 in.) (0.331 in.) (0.0006 in.) (0.0016 in.)
* TIR Total Indicator Reading (Measured On Vehicle)
** Referred to as ”14-inch” because they are designed to fit inside 14-inch or larger wheels. Actual rotor diameter is 262 mm (10.3 in.).
*** Referred to as ”16-inch” because they are designed to fit inside 16-inch or larger wheels. Actual rotor diameter is 302 mm (11.8 in.).
