2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2009 Avenger....running/parking/tail lights stop working
Old Nov 27, 2012 | 12:51 PM
rstarbuck's Avatar
rstarbuck
Default 2009 Avenger....running/parking/tail lights stop working
Problem: I have a 2009 Avenger that the running/parking/tail lights won't work. What does work is the head lights, turning signals and brake lights. What happens when I turn on the switch on for the head lights the dash lights flash off and on 6 times and stay off at that point and the running/parking/tail lights won't come on. I've looked at every fuse, every bulb and even changed the multi-switch that controls the head lights/running/parking/tail lights. Has anyone else had a problem like this before that could shed some light on what possibly could be the problem?
Old Dec 2, 2012 | 01:18 AM
lxman1's Avatar
lxman1
Site Moderator
Perhaps a bad power distribution box that all of the fuses are located under the hood.
Old Dec 2, 2012 | 07:52 AM
rstarbuck's Avatar
rstarbuck
thanks for the reply...I believe that you are correct. The Totally Imtergrated Power Module is the only thing left that it could be. I plan on sending it off to a company that will fix it and send it back to me. I hope it fixes the issue.
Old Dec 2, 2012 | 12:34 PM
lxman1's Avatar
lxman1
Site Moderator
Good luck. Keep us posted on the results.
