2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
08 Dodge Avenger Braking System Problems
Old Jun 4, 2013 | 09:23 PM
wgoforth's Avatar
wgoforth
Default 08 Dodge Avenger Braking System Problems
Hello,
I have an 08 Dodge Avenger 4cly 2.4.
I recently replaced all four brake pads and added fluid to the reservoir. We did not bleed the brake lines. After a few turns down the road the front check valve off of the master cylinder cracked at the middle o-ring and i and i lost braking. I had to purchase a new valve from the dealer and after replacing the new valve broke the same way.
Any suggestions on what to check next?
Old Jun 5, 2013 | 08:18 PM
wgoforth's Avatar
wgoforth
Current theory is that i have a blockage in one one the lines causing the pressure to back up and the outbound check valve to pop.
I plan on testing each line individually, will post what I find.
