2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
oil catch Install
Old Aug 4, 2014 | 09:03 AM
killian322's Avatar
killian322
Default oil catch Install
Does anyone on this forum have any experienc with installing the oil catch cans? and which is the best model to but? I have a 2014 Avenger R/T and want to get the right one the first time and need the instructions to install it, can anyone help?
Old Jan 11, 2015 | 03:24 PM
stevemcc0322's Avatar
stevemcc0322
this is where one guy mounted his
This is where I mounted mine
Its pretty easy to do and it doesn't really matter which one you get (as long as they are made right), the function is the same.
The one I have has two top openings instead of one top and one side and a level indicator to let me know when it need to empty it... but the function is the same...
Some where on the head you should have a hose that comes off and goes into your intake. Some where in the middle of that hose is where you want to install your catch can. I mounted mine on the firewall and used longer hoses to connect to the catch can and the intake.
