2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2008 Dodge Avenger 2.7L fuse 33 Continuously Blowing
Old Jul 28, 2019 | 11:21 AM
Al LaRiviere's Avatar
Al LaRiviere
Default 2008 Dodge Avenger 2.7L fuse 33 Continuously Blowing
Hi people, as the title says fuse 33 continuously blows in my car. The fuse is for the TIPM (PCM). The car will run for 10 seconds before the fuse blows. Key on engine off the fuse does not blow. I did some searching and a "mechanic" suggested to a poster that if fuse 33 is blowing without any other fuses being affected that it is most certainly the fault of the PCM. I have now replaced the PCM but the problem is persisting. I have opened all of the wiring harnesses on the engine side leading back to the passenger compartment and under the dash also but haven't been able to see any issues with shorts or breaks in the wiring.
Hoping someone can give me some insight as to where I should look next.
TIA, Al
Old Aug 17, 2019 | 12:28 AM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum. Have you checked the voltage of the alternator when it's running? I wonder if it is overcharging since it only blows when it is running.
