2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Need Help-HEAT ONLY COMES OUT ON DRIVERS SIDE
Old Sep 21, 2022 | 12:13 PM
Cquietman's Avatar
Cquietman
Exclamation Need Help-HEAT ONLY COMES OUT ON DRIVERS SIDE
I have a DODGE AVENGER 2011 MAINSTREET 2.4L, I've changed the blend door but still my heat only works on the DRIVERS SIDE, DONT KNOW WHAT TO DO, CAN ANYBODY HELP ME?
Old Sep 21, 2022 | 02:48 PM
Moving this to the avenger section for ya.
Welcome to DF!
Old Feb 21, 2023 | 08:33 PM
nickelo37's Avatar
nickelo37
Hello! Same issue happened for me. The issue is your heater core is clogged up. Go to Lowes and get the supplies, and watch the video below. We flushed backwards, then forwards, then backwards again. The two tubes to reach the heater core are located behind the engine on the fire wall. Best of luck! If you need any more help I can explain in more detail what we did.
