2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2014 Avenger SE 2.4 - Clicks a few times, no start
Old Jun 7, 2025 | 12:21 PM
Hocking-Hills-Ohio-Avenger's Avatar
Ok, I appreciate the input
Old Jun 15, 2025 | 10:24 AM
Another update. I bought a code reader and I'm getting a TIPM code P1270 - starter control circuit 2 open, and a WCM code B1A25 - Invalid Key., and PCM code P0513 Engine Control Module - Invalid SKIM Key
I put a new battery in the fob (the reader has a fix assist and that was a suggestion provided for the codes) and it is still throwing the codes.
I'm having a guy come tomorrow to make sure the key didn't lose it's programming and will have the key re-programmed if needed (and a couple of spares cut and programmed)
Hoping that is all it is, if not, I'll dig a bit deeper
Let me clarify, initially I got the P0513 code, I tried just deleting it and after I did and reran the diagnostic, it came back with the other 2 and P0513 was gone.
Old Jun 15, 2025 | 11:08 AM
Johnboy173's Avatar
Johnboy173
Default No crank
Good job,start with key problem,how many keys do u have, FYI I had 2 working keys and easily programmed extra key myself,easy and not expensive,
Old Jun 15, 2025 | 11:53 AM
Default No crank
I have 1 key we’ve been using. I bought 2 more and they haven’t been cut or programmed. They are the 4 button keys
im hoping to have those cut and programmed tomorrow and the original key fixed in whatever capacity is necessary
I’m hoping it was just the key needed reprogramming…
Old Jun 15, 2025 | 02:10 PM
Johnboy173's Avatar
Johnboy173
Default No crank
If u have only 1 key,supposedly u need to have a special process to program key/keys,Google it for info
Old Jun 15, 2025 | 02:17 PM
Default No crank
The guy that I have coming is a key specialist and and has the necessary program I believe to get the key back where it needs to be and get the new ones ready to go
im just hoping that’s the fix it needs.. if not its another possibility eliminated
Old Jun 15, 2025 | 10:06 PM
Johnboy173's Avatar
Johnboy173
Default No crank
Just to double check,,check owner manual on security system operation jic just in case,,,PLEASE DON T TOUCH ANYTHING til u get key checked,,GOOD LUCK
Old Jun 16, 2025 | 07:18 PM
Default No click
Update. New programmed key was the ticket.
Old key had not lost programming but wasn’t doing it.. 2 new keys cut and programmed and that did the trick
thanks all for the input and help
Old Jun 16, 2025 | 11:26 PM
Johnboy173's Avatar
Johnboy173
Default No crank
Your welcome, hope i helped a little
