Exhaust chopped of at cat!!
As long as your cat isnt rattling it will be fine for now I had stock cat with my magnaflows and it still sounded good I got my whole exhuast system off ebay for 275.00 thats tubing,muffler and hangers and clamps.
Its different in a dakota compared to a ram with my buddys ram the cat is like right under the passenger seat where mine is like a half a foot from the back of the cab I left the section of pipe that was before my muffler and it sticks out about half a foot from the cab so you wont get any exhaust smell and even when idling I still cant smell exhaust.
You won't smell exhaust, that's the whole point. Unless it's running extrememly rich, or has bad blow by, you would never know there's anything wrong. Ever seen a vehicle that has just run exhaust downturns/dumps in front of the rearend? Check out the damage/rust/corrosion to the trunk area. Seriously man, I wouldn't take the chance........
EDIT
I'm still fairly new at this, but is this what you guys are talkin about?
http://www.autozone.com/autozone/acc...ier=33377_0_0_
And what difference does the length of the tip make? Longer/more quiet, shorter/louder? .... And the diameter of the tip also?
From other threads I've read, the exhaust for my truck has a 2.5" inlet, so I'm assuming that as long as that's correct then the outlet size doesn't matter too much. I'm liking this one because it's definitely in my price range and it's clamp on (don't have to weld it). What do you guys think?
i havent had any issues with rust or whatever and i don even have turndowns, just hacked i off after my muffler and its about 2 feet from the rear axle. i mean when you are driving theres so much air moment that the gasses are dispersed as quickly as they come out the tip.
Ok cool. I've never noticed an issue with (rattling and such), so I'm assuming all will be ok ... at the very least for now. Will check out some mufflers for the truck. Thanks again for the help and suggestions!
Though I'm not sensitive to exhaust and it doesn't particularly bother me, I'd hate to do that to someone else ... especially since I've got a 6 month old boy. I'll hold off on chopping for now and stick to ramguy's suggestion.
EDIT
EDIT
I know that others here on the board have been talking about the 40-series FM mufflers for around $40-$50, but everywhere I've looked I'm unable to find anything under $70 ... which isn't too terrible, just not in my price range at the moment.
Am I completely missing something ?
That's true. I had a friend and his girlfriend that were sitting in his car. Car had a slight exhaust leak. It was cold weather, so they had the engine running and the windows closed. They found them both dead the next morning.
My condolences on your loss and appreciate you saying what I couldn't.
