2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Bi xenon problems
Old Dec 5, 2010 | 01:14 AM
00dakotaslt's Avatar
00dakotaslt
Default Bi xenon problems
wondering if ne1 has any answers for me, just got my vaga diamond bi xenon HID kit installed on my 00 dak and they are working fine hi and low however if i start the truck before i turn the head lights on the relay just makes a buzzing sound and my HIDs dont come on, but if i turn them on before starting the truck, they work fine. if neone got any answers id greatly appreciate it.
Old Dec 5, 2010 | 03:33 PM
dodgeramguy85's Avatar
dodgeramguy85
How is your power wire hook up is it going right to the battery?
Old Dec 6, 2010 | 12:54 PM
00dakotaslt
ya it hooks directly to the batt and got a 25amp fuse on it
Old Dec 6, 2010 | 01:00 PM
dodgeramguy85
What about starting the truck letting it run for a little bit then trying the lights does it do the same? Almost sounds like its not getting enough power after start up
Old Dec 7, 2010 | 08:38 PM
00dakotaslt
yah tried that but they still just make a buzzing sound
Old Dec 7, 2010 | 08:57 PM
dodgeramguy85
Im out of ideas only thing I can say to do now is call or email the place where you got them from and ask them.
Old Dec 8, 2010 | 03:22 PM
00dakotaslt
well thanx neways,really appreciate you trying to help. guess ill have to get a new kit and try cause i already contacted the seller however they didnt know what was causing it and wouldnt give me a refund. lol o well
Old Dec 8, 2010 | 03:32 PM
dodgeramguy85
Hopefully they are giving you a new one at no cost.
Old Dec 8, 2010 | 09:14 PM
Patrick Dennis's Avatar
Patrick Dennis
Had a similiar problem with my '97. Found the feed back from the high beam circuit to the Fog Lamp relay#1 was the problem. I cut the L3 (RD/OG) lead to pin # 85 and added a separate ground. This solved two problems: the HIDs worked great and the Fog Lamps worked independantly from the headlamps - can be "on" with either Hi or LO beams. Hope this helps. I have a circuit diagram if you need.
