2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
need some dak help
Old Dec 11, 2010 | 04:19 PM
daks_shadow01's Avatar
daks_shadow01
Default need some dak help
I just bought a '01 5.9l dak sport for about 4500. it ran great until about three weeks ago when the headers melted some plug wires and the throttle cable, i was thinking the tps was going bad because i read 2.19v at WOT but the slapped another one on and got just about the same reading, so i was wondering is that a normal reading? the throttle isnt as responsive as it was when i baught it and im at a stand still, any help would be appreciated thanks.
Old Dec 11, 2010 | 04:20 PM
thunder98110's Avatar
thunder98110
IIRC, idle should be like .4-.9ish and wot=4.5ish with no dead spots. maybe you just got a bad tps again.
Old Dec 11, 2010 | 04:33 PM
thunder98110
double post
daks_shadow01
well the one i tried out last, i pulled off the tb turned it with a flat head and read about 4.7v, but that was about a 1/2 turn and the throttle plate only makes a 1/4 turn... so not sure what to do?
Old Dec 11, 2010 | 04:43 PM
magnethead's Avatar
magnethead
If you can't get full throttle with the linkage attached, I'd start looking there first?
Old Dec 11, 2010 | 04:45 PM
daks_shadow01
... new to forums.... double post?
Old Dec 11, 2010 | 04:48 PM
daks_shadow01
already checked the throttle plate, had the wife push to the floor and it probably opened 90 to 95% so the linkage its self is ok.
Old Dec 11, 2010 | 05:09 PM
magnethead's Avatar
magnethead
Doh, i read your post wrong. I forgot that WOT is only 1/4 turn of the throttle shaft. Have to wonder if the melted plug wires messed up anythign electrical
Old Dec 11, 2010 | 05:50 PM
daks_shadow01
i hope not, they werent completely melted, just beginning to melt and deform, but the throttle cable on the other hand, started dripping on the headers... that sucked cleaning up lol... but other than that, physically nothing else looked damaged. but like i mentioned earlier the tps read the correct amount of volts when turned further.... have you or anyone tested theirs on this forum and read different?
Old Dec 11, 2010 | 07:06 PM
magnethead's Avatar
magnethead
no I haven't but I believe others have. How exactly did everything start melting? Put in the wrong places? Plug wires I can understand, but not throttle cable. Maybe somebody else can chime in.
