2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
belt squeal and charge issues
Old Apr 8, 2011 | 08:51 AM
00dakotaslt's Avatar
00dakotaslt
Default belt squeal and charge issues
hey, got a 00 dak slt with a 3.9 in it and the last 3 months the belt was squealing but then it would go away. However , i changed the belt a couple days ago, and i was driving around and the check gauge light came on the volt meter went down to 0 and the truck started to rev and then it dropped and shut off. Now it hasn't shut off since then but it is still squealing and the check gauges light still comes on. wondering if ne1 can help me out? i was thinking it was the alt but when i shut the truck off and turn it back on its fine for about 2 seconds then it squeals again??
plaese help!! the squealing is driving me insane!!!
Old Apr 8, 2011 | 09:24 AM
DakMan6704's Avatar
DakMan6704
Remove Alt. Take to Autozone and have tested. Fail; replace. Your battery may be quick behind if you keep running it down.
If the Alt is good, replace battery.
Another 3.9 guy might be able to attest if a tensioner or other bearing is known to go...
Old Apr 8, 2011 | 10:12 AM
00dakotaslt
thanks dakman, ill try that
