2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Electrical plug
Old Jun 28, 2020 | 02:13 PM
Island's Providers's Avatar
Island's Providers
Default Electrical plug
Does anybody know what this is..it was hanging from dash when i purchased truck last week...dodge dealers in Savannah are totally useless. It has power so it must plug into something but what???? Please help
Old Jun 28, 2020 | 02:39 PM
Dodge didn't differentiate wiring harnesses on their trucks. So, it's possible that plug is simply for an option you do not have. If everything in the truck works as it should, just tuck it up somewhere out of the way, and forget about it.
Old Jun 28, 2020 | 04:40 PM
Island's Providers
That's just it...when Turner ignition key..gauges dont move....all other interior electrics work. Lights radio but nothing happens??
I manually got starter to rotate engine but still no activity like truck is being told to turn on.
The plug test same current level as battery.
I've already checked all fuses and they read correct ohms with no obvious physical failure.
Could this be a breathalyzer interlock plug and the device has been removed.
Again thank all for your help
Old Jun 28, 2020 | 04:48 PM
That looks pretty stock..... can you bend yourself around to see if there is anything in range that it might plug into?
Old Jun 28, 2020 | 05:39 PM
Island's Providers
I
I've looked everywhere I can see...under over behind
I'm totally stumped
Old Jun 28, 2020 | 05:51 PM
What year is your dak? Do we have a service manual for it laying around??
Old Jun 28, 2020 | 10:06 PM
Island's Providers
yes....looked at wiring diagrams
Neutral safety switch
Ignition interlock
I did see a similar plug in youtube video for aftermarket radio installation
Instead of blue had a white strip of plastic
Unfortunately video made no reference to the plug or its function.
Thanks again
Old Jun 28, 2020 | 10:10 PM
Look in the component locator section, and check out the dash wiring harness, see which connectors might be in the right spot, then go to the connector pinout section, look up those connectors, and see if you find a match.
Old Jun 29, 2020 | 10:05 PM
magnethead's Avatar
magnethead
That is the power connector for a trailer brake controller. Specifically, looks like a tekonsha plug. The factory style "christmas tree" fastener throws me for a loop though. I think the truck-side trailer tow harness was a square 6-pin but I could be wrong. bright blue with no stripe is a rather uncommon wire color outside of trailer brakes. Or sometimes bright blue with a red stripe.
