P0133 Engine code
Old Apr 6, 2007 | 01:49 AM
boohoops's Avatar
boohoops
Default RE: P0133 Engine code
so the code for a bad sensor is P0133 ?
Old Sep 7, 2010 | 12:19 PM
Rantz's Avatar
Rantz
I am getting this code. I'm not sure where the wiring goes from the O2 sensor.
Can someone please confirm for me that this is the O2 sensor pre-cat on the drivers side?
Old Sep 7, 2010 | 03:35 PM
Rantz's Avatar
Rantz
For those who don't want to look it up, the code means:
P0133 (M) 1/1 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
More importantly, which O2 sensor is this referring to? I'm assuming that all of the O2 sensors on the truck are the same.
What is the big deal with splicing in an aftermarket one? ***Edit*** The OEM direct replacement O2 sensor from Advance Auto was $28
**Edit** According to my haynes manual, which my lazy @ss should have looked at to begin with, this is the precat O2 sensor on the drivers side
Also, I was unequivocally advised NOT to splice into the wires since they use such minute and precise voltage ranges.
Old Sep 8, 2010 | 10:36 AM
Rantz's Avatar
Rantz
It would appear that all of the O2 sensors are NOT the same. I'm going to stop by advance auto parts and see if they can narrow it down for me.
**Edit** It turns out that that the truck is very particular about which O2 sensor goes where. There are different part numbers for the different sides and even distinctions between pre cat and after cat sensors.
Old Sep 8, 2010 | 02:59 PM
Rantz's Avatar
Rantz
Okay so I was being lazy. I spent the effort and opened up my Haynes manual and confirmed that it is indeed the precat O2 sensor on the drivers side. I encourage people to get their haynes manual all of the time, but sometimes I need the same reminder.
I picked up the bosch O2 oem fit sensor for $28 from advance auto and I also picked up the special socket to remove them for $12. So $40 total. I'll work on switching it out today after work.
Old Sep 10, 2010 | 07:11 PM
Rantz's Avatar
Rantz
Replaced the O2 sensor today and had the code cleared. So far so good
It was a major PITA trying to get that effer unplugged and then plug in the new one. No joke, over an hour to unplug and then little under an hour to get the new one plugged in. Absolutely necessary to unplug the evap hoses that are in the way of the plug.
Old Mar 2, 2024 | 07:11 PM
RRF's Avatar
RRF
Default Long term fix.
Was this a long term fix and did the code return?
Thanks
