Bearing or out of align
I took the clips off and I tried to hit the rotor (on the non contact areas) with a 2lb hammer, but I did hit it with all my might or anything. There's nothing wrong with the rotors so I don't need to replace them. I sprayed some PB Blaster, but I'll try hitting it harder.
I read in the Haynes book that it said if the bearing needs to be replaced that the bearing and hud assembly are all together and if you have to replace the bearing you have to replace it all. Is that true? I saw autozone has the bearing for about $80 and the bearing & hub assemble like $160.
As far as I know the bearing and hub assembly have to be replaced as one unit.. not sure if you can take it apart but if you do you will need a good press to press the bearing back in.. I just bought the bearing and hub unit and replaced it..
ORIGINAL: tntitans21399
so ur taking it off for what reason???
