rotors
Old Apr 18, 2007 | 03:39 AM
kissfan4's Avatar
kissfan4
Default rotors
ok so my front rotors are warped. what is a good replacement? and one that will not break the bank while doing so.
Old Apr 18, 2007 | 09:49 AM
Razorhorn's Avatar
Razorhorn
Default RE: rotors
I just did this two or three months ago on my '01 4x4 4.7L. I went with Wagner part number BD125632. No problems since - seems to be fine. I think the out the door bill was around $100 for a pair.
Old Apr 19, 2007 | 12:40 AM
imnothot02's Avatar
imnothot02
Default RE: rotors
i baught mine at o rielys bout 80 i think? for the pair they seem fine 6000 miles on em...city driving not warped yet..
Old Apr 19, 2007 | 12:52 PM
kissfan4's Avatar
kissfan4
Default RE: rotors
are drilled and slotted any better? i heard they were, then i also heard the were worse cause it decreases the surface area.
Old Apr 19, 2007 | 06:47 PM
Razorhorn's Avatar
Razorhorn
Default RE: rotors
You're asking for an opinion, so here's my $0.02. I spent a lot of money on a set for my Corvette that were supposed to make such a phenomenal improvement in the cars breaking performance that I would dance and sing. I didn't notice anything. I mean no improvement. I'm not saying it didn't improve, but my times didn't show it and I just didn't notice it.AndIam pretty sureyou will never drive your Dakota as hard as I drive that Vette.
Learn from my mistake and save your money.
I already told you what my opinion's worth
Old Apr 19, 2007 | 10:25 PM
imnothot02's Avatar
imnothot02
Default RE: rotors
makes em weaker, but helps gas escape... depends where do you drive the thing on the track off road highway city...?
Old Apr 19, 2007 | 10:48 PM
Chris's Avatar
Chris
Default RE: rotors
Drilled and slotted rotors allow gases to escape and keep the rotor itself cooler. If your problem is warping rotors, give the slotted and/or drilled rotors a try. As performance goes, there is a smaller contact patch, but that difference is outweighed by the fact that the rotor is cooler. Also, you wouldn't notice much of a difference if you didn't switch pads at the same time. Going with a ceramic brake pad and a drilled/slotted rotor would be the best route, and surprisingly cheaper than you would imagine. Check out eBay for the parts.
Old Apr 19, 2007 | 10:52 PM
imnothot02's Avatar
imnothot02
Default RE: rotors
not good offroad, you may want to just get treated rotors....
Old Apr 20, 2007 | 01:42 AM
kissfan4's Avatar
kissfan4
Default RE: rotors
it is driven on the highway and the city. but i do pull a 2000 pound boat with the truck. the boat trailer does not have brakes so the rotors are taking that as well
Old Apr 20, 2007 | 01:48 AM
imnothot02's Avatar
imnothot02
Default RE: rotors
go w/ somthing like http://www.autoanything.com/brakes/6...aspx?kc=ff1568
dont get the cheap crap off ebay, most likley they are jsut cehap metal rotors that arnt tempered, i guess for a lack of a better word,,,
