Factory speakers
Old Apr 21, 2007 | 01:43 PM
rlw_1224's Avatar
rlw_1224
Default Factory speakers
Does anyone know what the factory speaker sizes are for a 2000 quad cab? Looking to possibly ugrade them to something of a higher quality....
2000 Dakota SLT
4.7 V8
K&N intake, Clear corners, blackouts, truxedo cover, Dual Flowmasters
Old Apr 21, 2007 | 02:31 PM
imnothot02's Avatar
imnothot02
Default RE: Factory speakers
6 3/4 both front and rear, however you will probably need adapters, because its kinda a uncommon size, ull find lots of 6 1/2 speakers...the adapters are available form any quality car audio store.
Old Apr 23, 2007 | 11:34 PM
tufrthnails's Avatar
tufrthnails
Just go to your nearest best buy. They will show you what you need. Then get the part number of what you want and look them up in the net. I have found a lot of equip that way for a lot cheaper. As far as adapters I haven't changed the speakers out in my truck yet. so I don't know
Old Apr 23, 2007 | 11:40 PM
tufrthnails
Hey I actually just went online because I was curious. The fit guide I just looked at Said you need 6 1/2" speakers. I am not going to say imnothot02 is wrong. There may be a adapter but the guide did not say anything about it.
Old Apr 24, 2007 | 12:12 AM
imnothot02's Avatar
imnothot02
most models should, they come with tabs on the speakers, todo it the way that i recommend i use the adapters... also change ur eck the factory stereop rms's at like 10 watts per channel
Old Apr 24, 2007 | 04:02 AM
Rakaric's Avatar
Rakaric
I thought factory speakers are 6.5 to begin with. I pulled all 4 out of my club cab and they were 6.5" I replaced the rears just this weekend actually. If you want new speakers, they are usually 30 - 45W RMS. I recommend getting a new radio. I got new front speakers, which were I think 30W @ 190W peak after I got my cassette deck. It has a rating of 45W x 4. At a high enough volume, I notice the sound was actually decreasing itself cuz the factory speakers cldnt handle the wattage. These were the new speakers: http://www.circuitcity.com/ssm/Pione...oductDetail.do
I just bought new speakers for the rear with a rating of 40W @ 300W peak. They were like $30 and they are VERY strong with bass for it's size which is a 6.5". I was rather impressed.
Old Apr 24, 2007 | 11:52 PM
jk240sx's Avatar
jk240sx
Check out www.crutchfield.com . they have all the fit guides and will provide adapters to factory harnesses.
