water pump ideas
Old Apr 21, 2007 | 10:45 PM
98Dodger4x4's Avatar
98Dodger4x4
Default water pump ideas
going to replace my leaking water pump on my 98 dakota 5.2L. DoI need any specail tools? Also anyone about how long the job takes?
Old Apr 22, 2007 | 01:04 AM
imnothot02's Avatar
imnothot02
Default RE: water pump ideas
i havnt pn mine as of yet, this would be a good time for ya to do a how too for the rest of us tho...
Old Apr 23, 2007 | 10:07 AM
MoPaul's Avatar
MoPaul
ratchet and sockets, don't recall what size, nothing problematic
pipe wrench for the fan
wire wheel to clean up gasket surfaces
gasket sealant and gasket
may as well do the thermostat while the system is drained, my opinion
i changed my timing chain as well, although it didn't seem to need it, new one is as sloppy as the old one, guess that's how it's supposed to be
Old Apr 25, 2007 | 01:14 PM
xVeNoMx's Avatar
xVeNoMx
Hey...
I started to do the pump on my 2002 3.9L, picked up the pump myself from Crappy Tire and I ran into the problem of the spanner tool needed to remove the fan from the clutch... I went to Part's Source to get a loaner tool but it wasn't the correct tool.
So i took it to the garage and had them put the pump on... only to find when I drove it home it was still leaking fluid so I brought it back to the garage the next day and they told me it was a faulty pump.
Rough $500.00 later it was fixed. Hoorray!
Old Apr 25, 2007 | 02:57 PM
horatio102's Avatar
horatio102
Crappy Tire... you're a Canadian eh?
[sm=icon_rock.gif]
Old Apr 25, 2007 | 06:11 PM
xVeNoMx's Avatar
xVeNoMx
Yup... and never again to Crappy Tire for parts again...
Old Apr 25, 2007 | 07:11 PM
Erich_121's Avatar
Erich_121
Its really not that bad, but write down where all the bolts go because most are different sizes and you will never remember where each one goes. It shouldnt take you any more then 4-5 hours. you might want to buy a strap wrench to help hold the water pump pulley while you turn the fan clutch bolt.
Old Apr 25, 2007 | 10:12 PM
imnothot02's Avatar
imnothot02
^^^ pen paint is a must...for lotsa things like this...
