Pulling my Hair out
Old Apr 24, 2007 | 11:21 PM
Fetch4TX's Avatar
Fetch4TX
Default Pulling my Hair out
Please Help.
Here it goes.
I have a 2000 Dakota 4x4, 4 door, 5.9l, 94,000 miles on her.
Sarted smelling antifreeze a few months ago.
I dont drive it all the time so I put this off.
Changed hoses,Clamps and cap.
I cant find where its coming from, but when it gets hot I can smell it worse.
I put a press check on it and it hel 15 lbs for 2.5 hours.
anyons know whats going on??/
Old Apr 25, 2007 | 12:01 AM
imnothot02's Avatar
imnothot02
Default RE: Pulling my Hair out
bad cap? realy if its good for 2.5 hours...but it may have a pre mature release on the cap...
Old Apr 25, 2007 | 12:04 AM
jonnymagnum's Avatar
jonnymagnum
do you smell it when your inside your truck? if you do, then its your heatercore.
and it probly could be your cap.
Old Apr 25, 2007 | 02:16 PM
Billiam's Avatar
Billiam
I'll have to agree with jonny on this one.
Old Apr 25, 2007 | 07:30 PM
JBs DAK's Avatar
JBs DAK
Do a pressure-test AFTER it's hot. Be sure the thermostat is open.
Smell it on the inside; Heater-Core.
Smell it on the outside; Could be anywhere.
Old Apr 25, 2007 | 07:36 PM
jonnymagnum
ya, I would get the truck nice and hot, then take the rad cap offJ/K you'll only do that once[:@]
but I would hook up the pressure tester when your trucks cold, then get her nice and hot for the stat to open, then you will be checking for leaks in the whole system, not just the rad.
Old Apr 25, 2007 | 08:31 PM
Fetch4TX's Avatar
Fetch4TX
I did replace the cap a few months ago, and a new one came with the uper hose assmbly.
I smell it inside, but mostly outside the truck.
Im going to try the hot test tomorw.
I guess if that doesnt tell me anything, I can bypass the heater core and see if it stops, huh?
And it really smells like antifreeze when ya pull that cap off hot..
Old Apr 25, 2007 | 10:15 PM
imnothot02's Avatar
imnothot02
be sure to post back!
Old Apr 26, 2007 | 11:44 AM
Casper50's Avatar
Casper50
ORIGINAL: Fetch4TX
Not to mention that hint of burning flesh smell that you get! [:@]
Old Apr 26, 2007 | 06:33 PM
jonnymagnum
ORIGINAL: Casper50
ORIGINAL: Fetch4TX
I had an indentation of the rad cap and a burnt arm when I did it.
I was 17 and my old bronco over heated...... so I decided to check the coolant I learned my lesson the hard way, even though it should be common sense.
