Threw this code today P0455
Old May 8, 2007 | 12:13 AM
Big_Blue's Avatar
Big_Blue
Default Threw this code today P0455
Now what
P0455 (M) Evap Leak Monitor Large Leak Detected A large leak has been detected in the evaporative sysem.
Old May 8, 2007 | 12:19 AM
Mean Green's Avatar
Mean Green
Default RE: Threw this code today P0455
Get under the Dak and start following your fuel lines looking for cracks or holes. The most common area for this to happen is in the filler neck so check there first.
Old May 8, 2007 | 12:24 AM
imnothot02's Avatar
imnothot02
new gas cap correct...? mine threw that fora cap, well that and i always filled up with gas when the truck was runnin..
Old May 8, 2007 | 12:28 AM
Mean Green's Avatar
Mean Green
Cap is usually a small leak.
Old May 8, 2007 | 12:31 AM
imnothot02's Avatar
imnothot02
this is correct, but never know...easy fix if it hasnt been done people dont know that filling whrn running would cause this too..
Old May 8, 2007 | 04:19 AM
boohoops's Avatar
boohoops
correct me if im wrong but last time i checked, the evaporator was part of the ac system, not the fuel system
Old May 8, 2007 | 02:29 PM
jonnymagnum's Avatar
jonnymagnum
ORIGINAL: imnothot02
filling up with the truck running could cause alot more then a code what gas station lets you keep the truck running?
but it could be a bad hose to your charcoal canister.
Old May 8, 2007 | 11:57 PM
4x4kota's Avatar
4x4kota
I had the same code, my hose by the emissions evap service valve was cracked, so i cut off an inch from the end, reset the computer and was good to go.
Old May 9, 2007 | 01:57 AM
98R/TDak's Avatar
98R/TDak
would a vacuum line cause that code to appear? either one falling off or cracked?
Old May 9, 2007 | 10:18 PM
imnothot02's Avatar
imnothot02
yes..
