Time To Change Spark Plugs, NGK? Bosch?
RE: Time To Change Spark Plugs, NGK? Bosch?
do oil change, cap, rotor, wires, plugs, run some sea foam,
I have Autolite 3923's in mine running MSD Ignition, the autolites run a little cooler, so it helps a bit, it has been said that people dynod the plugs and they gain hp.. not much, but better then nothing.
Champ and Autolite 3923's are what i would go with, and either Accel or MSD wires... make sure when you cut them and build them to use the long boots.. 90 degree dot work to well. lol (thats what i did) burnt a wire within acouple of weeks on the header ad was getting a misfire, had a friend in tha Dak club sell me a set of long boot premade for 20$ so i didnt have to go out and spend another 100$ a wires..
ORIGINAL: User2006
ORIGINAL: Big_Green
Well i just got a tune up at the dealership, does that mean i cant use since my oil is new or can i still do it? Or is it best to do it when your going to change your oil? Can i run Autolite 3923's too?? I know yours is a 5.9? Or would i be different since im a 5.2? Or i would run Champion Iridium or Champion Platinum. Wat would be better the Iridium or the Platinum? Then i would most likley put in MSD wires or Accel what ever is cheaper. Sounds like a good way to spend a weekend working on the truck!!
ORIGINAL: User2006
Yes the plugs will work, they come pre gaped at .40 so you dont need to do anything to them, MSD is more expensive, but worth it. Never use Platinum or Iridium in our engines.. stock to stock or normal copper.. the only diffrence is they last longer, but useally give our engines more misfires i had Bosch Platnium in mine for 2 weeks and i was getting a misfire in every other cyl.. i took them out replaced with autolites everything worked fine.. those damn platniums where like 50$ for 8 i got the autolites for 10$ for all 8...
also you can change the plugs and wires in about 30 min to an hour.. its not a weekend job..
Ya im going to do it today. So i can just go and ask for Autolite 3923? How long do they last for? Then i will buy some nice MSD wires! Hope my truck runs good afterwards
So next time i do a oil change i can run some sea foam in it. Were do i put it in the tank or the engine?
