HELP!!! PLZ HELP!!!
RE: HELP!!! PLZ HELP!!!
I had the EXACT same problem less than a month ago, and yes, it is the Central Timer Module. Remove the kick plate next to the e-brake and smell the little black box that's under there. You can't miss it, it has a ton of wires plugged into it. If it smells burned, kiss 400 bucks goodbye. Personally, I wouldn't trust getting this part from a salvage yard, and you will still have to get it re-programmed at the dealer. Why so many things are controlled by this module is beyond me.
