Hard to start
Old May 28, 2007 | 02:42 PM
TexasNative's Avatar
TexasNative
Default Hard to start
Okay first time Ive had to post a problem on here...Went to the beach a couple of days ago fishing came back and went to the car wash to rinse it off....I rinsed it and got some water under the hood but not much. It wouldnt start, it would crank though finally after about 10 mins it started but ran REALLY rough. It has done this before but not as bad. Now I have to try for 10 minutes before it finally starts and runs. I hooked up my programmer and recieved no trouble codes. That being said Im lookin for help from anybody......
Old May 28, 2007 | 04:49 PM
98R/TDak's Avatar
98R/TDak
Default RE: Hard to start
i had that on an old truck of mine the starter was bad everytime somethin got went under there the starter wouldnt work then eventually died...i think there was some exposed wires under there...if its running rough and u have to wait it sounds like theres some sort of wire that was exposed to the water, check all ur spark plug cables for any wear thru the shielding, check wires going to alternator and starter to make sure there covered and not exposed as well
Old May 28, 2007 | 04:52 PM
TexasNative
Thanks for the info I will double check them......
Old May 28, 2007 | 04:53 PM
Dakoter's Avatar
Dakoter
simply check to see if moister is geting under your distributer cap, and check your coil, coil packs as weel check for loosness, and or cracks.
Old May 28, 2007 | 09:16 PM
f0x672's Avatar
f0x672
^ +1 on the distributor cap... if the starter was getting full of water, etc it wouldnt even crank or do squat
Old May 28, 2007 | 10:12 PM
imnothot02's Avatar
imnothot02
+2
Old May 28, 2007 | 10:24 PM
TexasNative
Thanks for the info guys....what did yall mean by ^1 and +2???? ANyways the HEAT in South Texas seems to have dried it all out but the real test will be tomorrow morning before work lol....
Old May 29, 2007 | 01:43 AM
V8Boss's Avatar
V8Boss
I had the same problem minus the running rough. Ended up that I had bad battery cables and wouldn't start till they dried.
Old May 29, 2007 | 02:13 AM
4x4kota's Avatar
4x4kota
yeah i had an old ranger that after hitting big puddles or getting too much slush and snow from the road under the hood would cause the truck to stall. lol. I also agree on the distributor cap. and FYI... ^+1 and +2 means that they agree with the post ahead.
