How to find axel ratio
Old May 29, 2007 | 10:04 PM
jepittma's Avatar
jepittma
Default How to find axel ratio
I'm looking at buying a 1997 Dakota sport- 4X4- 5 spd manual -5.2 ltr V-8, with factory installed tow package. I need to pull my boat that weighs 4,600 pounds. I think that year they put three different axel ratios on the manual dakotas. Theguy I'mbuying it from doesn't know which one it has. Is there a fast way to figureit out. I just need to be sure it can pull my boat. Thoughts?
Old May 29, 2007 | 11:03 PM
unclepudge's Avatar
unclepudge
Default RE: How to find axel ratio
It's in the glove box on the tag on mine?
Old May 29, 2007 | 11:28 PM
Mean Green's Avatar
Mean Green
Yup in the glove box or if for some reason the sticker is gone you can climb underneath and read the tag on the rear diff. I would just get the build sheet from the dealer though you will get all the info you are looking for then. A little FYI if it is a factory installed tow package chances are it has the 3.93's.
Old May 30, 2007 | 05:03 AM
horatio102's Avatar
horatio102
3.92, but close enough.
Here's the easiest way:
Put the truck in 4th gear.
Release parking brake.
Mark crank pully.
Push truck forward 1 full revolution of the tires.
Calculate how far the mark has gone around. It should be 3.92 times or 3.55 times.
Old May 30, 2007 | 06:59 AM
Mean Green's Avatar
Mean Green
I always keep thinking 3.93's no matter how muich the right numbers are thrown at me. In any case you know what I mean.
Old May 30, 2007 | 02:18 PM
horatio102's Avatar
horatio102
My ram came with 4.10 up front and 4.11 out back, from the factory. I think it would be safe to say that there might be a 3.93 available for some axle, but the late model Chryslers are all 3.92. >shrug<
Old May 30, 2007 | 05:49 PM
f0x672's Avatar
f0x672
ORIGINAL: horatio102
[sm=WTFsgign.gif]... that doesnt make any logical sense but alrighty then
Old May 30, 2007 | 07:12 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
umm yea thats what i was thinking, how did that work out???
Old May 30, 2007 | 07:51 PM
jonnymagnum's Avatar
jonnymagnum
ORIGINAL: f0x672
my 82 ram had that too.
