clicking/ticking noise while coming to a stop
Old Jun 13, 2007 | 12:10 PM
reeserx's Avatar
reeserx
Default clicking/ticking noise while coming to a stop
when im slowing down and coming to a stop..i hear a clicking noise, i have no idea where its coming from, its just a clicking noise when i come to a stop..any ideas?
Old Jun 13, 2007 | 01:28 PM
f0x672's Avatar
f0x672
Default RE: clicking/ticking noise while coming to a stop
most common question on the board, just search next time but, its either your evap pump solenoid or its the valves or timing chain, common issue, no cause of concern though, welcome to the forum
Old Jun 13, 2007 | 01:30 PM
reeserx's Avatar
reeserx
ok good...thanks for the welcoming and the answer
Old Jun 6, 2009 | 04:47 AM
tbird's Avatar
tbird
If you're hearing the ticking when you're applying your brakes, I'd look to the ABS system. I'm in the process of trying to find out exactly how to get this fixed, but I was told by a repair shop that it was the brake pressure limit valve, part of the ABS system that was ticking. Only problem is that they can't say for sure whether replacing the part will solve the problem, or if it's something else that's making the valve tick. Pull your ABS fuse and see if the ticking stops. I did this and the ticking did stop, but then my speedometer didn't work so I put the fuse back in. This should at least tell you whether it has something to do with the ABS system. By the way, any problems with you're ABS/brake lights going on?
Old Jun 6, 2009 | 02:53 PM
f0x672's Avatar
f0x672
thanks for reviving a 103** week old post....
edit: haha long night last night, my bad
Old Jun 6, 2009 | 03:04 PM
dhvaughan's Avatar
dhvaughan
actually its 103 weeks old (2007). i wonder if its still ticking ? LOL
Old Jun 7, 2009 | 04:00 AM
tbird's Avatar
tbird
Nice to know there's a bunch of know it all smart asses in this forum. It probably is still ticking when f0x672's answer to everything is the timing chain. LOL. Guess you missed the part where he said it's when he was braking dip ****. And what do you have to contribute dhvaughan. Nothing except being a dip **** along with f0x672. You're probably both gay **** heads. f0x672 probably paid $100 for a BJ from dhvaughan.
Old Jun 7, 2009 | 12:47 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
easy turbo
