02 3.9L Starting Problems
Old Jun 26, 2007 | 01:12 PM
EPA570's Avatar
EPA570
Default 02 3.9L Starting Problems
Hi everyone,
Nice forums you have here. Was hoping somebody might have a direction I can go get my truck to strart again. It died this weekand I cannot seem to be able to get it to start. This is what I have done so far. The truck is completely stock.
1. Checked the fuel system and fuel pump works and it is getting fuel pressure to the rail.
2. I have replaced all the igintion stuff......wires/rotor/cap/plugs...needed it put didnt fix it.
3. There seems to be no spark. I remove 2 plug and grounded and I am not getting a spark.
4. I also grounded the coil wire coming from the coil and I also see no spark. I get 10-12 volts on input of the coil but I can find anything in the book to tell what other tests I can do to make sure thats the problem.
5.What else can I check just to verify its not sensor somewhere.
I am trying to determine if that is the best way to test the coil and what else I need to do to make sure it isthat before I spend the money. Do the coils on these truck go out alot?
Thanks to Anyone that can help.
Eddie
Old Jun 26, 2007 | 04:19 PM
f0x672's Avatar
f0x672
Default RE: 02 3.9L Starting Problems
sounds like your coil is definately gone...
Old Jun 26, 2007 | 07:43 PM
ltl grn dakota's Avatar
ltl grn dakota
check your cam postion sensor in the distrbutor , mine went last week. the dealer ended up replacing the distrbutor becauseof a faulty bushing . also check the crankshaft postion sensor. no signal no spark.
hallalua for extended warranties.
Old Jun 26, 2007 | 08:23 PM
EPA570's Avatar
EPA570
Can you point me to something that will tell me how to test the sensors... Can it dont with a voltmeter or it is something I cant do myself?
Old Jun 26, 2007 | 09:45 PM
varsis's Avatar
varsis
Does other electrical work? Like your battery might be gone or alternator.
Old Jun 26, 2007 | 11:31 PM
EPA570's Avatar
EPA570
I tested the coil the resis. are 1.7 and 17k. Are these too high or is this acceptable?
Old Jun 28, 2007 | 12:09 AM
EPA570's Avatar
EPA570
OK we replaced the coil and it still wont start.. Kinda at a lose as to what else it could be.
Old Jun 28, 2007 | 01:38 AM
imnothot02's Avatar
imnothot02
no spark at all, correct..
have the distributor checked first, be my guess..
Old Jun 28, 2007 | 12:33 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
he already replaced it i would check the cam position sensor personally, or replace it if the $$$ is there id just replace it right out
Old Jun 28, 2007 | 05:19 PM
deranged's Avatar
deranged
The cam and crank position sensors are prone to trouble. Better check 'em.
