Red line?
Old 07-02-2007, 06:07 AM
Big_Green's Avatar
Big_Green
Big_Green is offline
Default Red line?
So i know this a pretty dumb question. But im going to ask it anyways. Tried looking it up and could fine nothing. What is red line on the dakota's? i got a 99 with a 5.2. Only mods are exhaust, home made cold air intake and autolite plugs. Put i dont think the plugs would count as a major mod. It says red line is 4600 or 4700. but could you go higher without messing anything up?
thanks
PS Happy Canada Day
Old 07-02-2007, 06:04 PM
Big_Green's Avatar
Big_Green
Default RE: Red line?
no one?
Old 07-02-2007, 06:08 PM
Chris's Avatar
Chris
Chris is offline
You can raise your rev limiter using an aftermarket programmer such as hypertech or superchips.
Old 07-02-2007, 06:09 PM
RP Racing940's Avatar
RP Racing940
RP Racing940 is offline
No reason to go to redline. Power starts to drop off before redline.
Redlines are put in for a reason. Go over it it may not hurt it right away, but repeatedly will destroy the motor.
BTW the limiter will kick in before you get that far anyways.
Old 07-02-2007, 10:18 PM
340Dak98's Avatar
340Dak98
340Dak98 is offline
my rev limit must of been broke when I had the 3.9 in my 98 Dak, it has hit 5500 a couple of times on wet pavement. Engine ran like crap for a day or so the few times i did, but overall was ok. Oh....but then I did spin a cam bearing one day on the interstate 2 months ago...but engine was 8 years old with MANY miles.
Old 07-02-2007, 10:22 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
idk mine has the redline on the tach starting just below 5k, but my dads 03 doesnt have it on the tach, and his tach goes to 7k, mine only goes to 6k, so idk but i dont see any way to get it reved that high anyway
Old 07-02-2007, 10:27 PM
superdak05's Avatar
superdak05
superdak05 is offline
mine pulls to 6000 but i have the cams and pcm flash.
Old 07-03-2007, 02:44 AM
98R/TDak's Avatar
98R/TDak
98R/TDak is offline
mine stock goes to 5500 before the limiter kicks it out, i have a 98 r/t i hope thats right? its a little bit past red line and ive only hit it like twice..once by accident
Old 07-04-2007, 08:02 PM
Big_Green's Avatar
Big_Green
No i was just wondering what it was at, since the the RPM only goes up to 6 grand. I will be buying a Superchip program soon thou, any other brands out there that can compeat with superchip?
Old 07-04-2007, 10:05 PM
jonnymagnum's Avatar
jonnymagnum
jonnymagnum is offline
I would stick with superchips. it has the most options and you can view/erase codes with it too
Quick Reply: Red line?
