Audio System
Old Jul 5, 2007 | 12:03 PM
ZiggyNeon's Avatar
ZiggyNeon
Default Audio System
has anyone one hooked up a Sub and amp in there truck ? just asking to see if someone has a good ground location so i dont spend an hour finding one
thanks
Old Jul 5, 2007 | 12:36 PM
xVeNoMx's Avatar
xVeNoMx
Default RE: Audio System
I mounted my amp under the seat and used a screw to ground it close to the seat belt roller.. there was another ground close to there so I figured it would be decent.
Old Jul 5, 2007 | 01:46 PM
Billiam's Avatar
Billiam
I did, but I probably have a little more room then you do. So for me it my sub went behind the backrest on the single bench seat in the back. The Amp went under the seat.
Old Jul 5, 2007 | 01:57 PM
chris0211's Avatar
chris0211
I have a 12" Infinity w/ 1000w Kenwood Class D Mono. in my single cab and i just pulled up the carpet where my jack is at. you got ext. cab so you shouldnt have any problem at all. (i wish a had the ext)
Old Jul 5, 2007 | 01:59 PM
ZiggyNeon's Avatar
ZiggyNeon
well i dont like the way dodge did the ext cabs... they should of did it like the rangers and s10's where the jump seats fold down from the sides...
so my current project now is to find a way to modify it so i have one jump seat behind the passenger side seat and thats it
Old Jul 5, 2007 | 04:37 PM
Chris's Avatar
Chris
I used a bolt holding the rear seat down.
Old Jul 5, 2007 | 04:56 PM
jonnymagnum's Avatar
jonnymagnum
I have my amp sitting behind the drivers seat and the ground to the bolt on the back of the drivers seat. I currently have two 12's sitting on my back seat, but looking at making a custom box to fit under the back seat.
Old Jul 5, 2007 | 05:12 PM
ZiggyNeon's Avatar
ZiggyNeon
see...i thought about the whole under the seat thing...but my wife stands at 5'3" like 120...and has no room when she sits back there. and thats what led me to try and customize the rear so the seat folds up on the side and not up on the rear
Old Jul 5, 2007 | 05:51 PM
jonnymagnum
I find my rear seat useless. unless theres a kid back there, cause the seat is too small for an adult.
Old Jul 5, 2007 | 09:16 PM
heavyk298's Avatar
heavyk298
Chris, where did you put the sub? theres hardly any room to fit a sub back there, i also have the regular cab.
