Rear end gear ratio?
Old Aug 2, 2007 | 01:54 PM
mbreitba's Avatar
mbreitba
Default Rear end gear ratio?
What's the best way to figure out what rear-end I have in my Dakota? I'm going to be pulling a boat, and according to the manual, I can have a GVWR of 9200 or 9400 with one gear ratio, and 10500 with the deeper gears (3.92 I believe). How do I tell which I have?
Old Aug 2, 2007 | 03:28 PM
bruno426's Avatar
bruno426
Default RE: Rear end gear ratio?
look at the sticker on the underside of the hood. should tell you axel type and gear ratio
Old Aug 2, 2007 | 10:15 PM
User's Avatar
User
if you cant find it on text or stickers, spin the driveshaft and mark the tire.. count the number of full turns the shaft makes when your tire goes one full rotation. and up the number of times you rotated the shaft and thats what you got.
Also on your dif case there should be little metal tags that say what ratio you have along with axle type.
Check your Owners manual...
Old Aug 2, 2007 | 10:45 PM
englitrob's Avatar
englitrob
Check the build sheet sticker in the glove box. Ive got an 03 R/T and it lists my truck with a 9.25 rear end and 3.92 gears.
Old Aug 3, 2007 | 01:03 AM
wink2873's Avatar
wink2873
all R/T's came with a 9.25 rear end with 3.92 gears. mbreitbaif your truck is an SLT it probably has 3.55 gears.
Old Aug 3, 2007 | 03:46 PM
SinCity R/T's Avatar
SinCity R/T
ORIGINAL: wink2873
Not allR/T's - some of the earlier models came with 3.55's from the factory. Once in awhile you can find an oddball that didn't come with AC, didn't come with power windows/locks, etc.
Old Aug 3, 2007 | 04:19 PM
wink2873's Avatar
wink2873
more than likely if an R/T doesnt have power windows and stuff, someone faked one by putting a 5.9 and R/T rims with decals and stuff. I have never seen or heard of an R/T comming from the factory with 3.55's.
Old Aug 3, 2007 | 04:25 PM
SinCity R/T
ORIGINAL: wink2873
They're real R/T's - I've met the owners & seen the trucks in person over the years. Power Locks/Windows, A/C, 3.92's, etc. were not always mandatory options for R/T's, but that is how the vast majority of them were produced.
Old Aug 3, 2007 | 04:36 PM
dapirate559's Avatar
dapirate559
i believe that it has the 3.92 gears. i have a 04 with the 4.7 and it has the 3.92 gears.
Old Aug 3, 2007 | 05:06 PM
TheePlaymaker's Avatar
TheePlaymaker
it is in the glove box to make things easy but if it has the factory tow package it should have 3.92's im not 100% sure about that but all the ones i've seen have been like that
