Need ground cable. Alternative to $700 dealer harness?
Old Aug 7, 2007 | 12:12 PM
cbergst's Avatar
cbergst
Default Need ground cable. Alternative to $700 dealer harness?
2001 Quad Cab 4WD 4.7
The ground terminal is badly corroded and broken. Dealer says it only comes as part of the complete $700+ engine harness kit. Anyone know of any aftermarket alternatives for the ground cable? Any referrals would be appreciated.
Clint
San Jose, CA
Old Aug 7, 2007 | 12:21 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Need ground cable. Alternative to $700 dealer harness?
if its only the terminal. then cut the end off it and put a new end on it.
Old Aug 7, 2007 | 12:24 PM
User's Avatar
User
er... do you need a cable or a terminal?
Also this is the part on your battery right?
If so.. hell no you dont need a 700$ harness.. never go to the dealership unless you have a warrenty.. they will overcharger like a ****.
You can go pretty much anywhere and find a new terminal, and you can use any type of 8 gauge wire for the ground...
if its broken i would just cut it off and strip some of the wire back and crimp on a new terminal.. most it would cost is about 10$.. THE MOST! Thats new wire and a ternimal, but im pretty sure you can find some slack in the wire and reuse it.
3$ for the terminal at walmart or you can go heavy duty and get a better one for like 5$ or so..
Old Aug 7, 2007 | 01:56 PM
Razorhorn's Avatar
Razorhorn
ORIGINAL: cbergst
Clint
San Jose, CA
This is a definite candidate for after-market or customized solution to save yourself a boat-load of money.
But, let's get more specific. Are you talking about the ground strap between the block and chassis? If so, there are probably some after-market straps out there for your application. Here's an example of one from Summit Racing -
http://store.summitracing.com/partde...p;autoview=sku
Old Aug 7, 2007 | 02:44 PM
dapirate559's Avatar
dapirate559
ORIGINAL: cbergst
Clint
San Jose, CA
dude which dealership did you take it to. stevens creek or capitol? i live in the san jose area. you can go to kragens or auto zone and buy a new cable and terminal and be done in half an hour max. just let me know if you need some help. ill send u my phone number.
