Engine Cleaning
Old 08-10-2007, 04:12 AM
chris0211's Avatar
chris0211
chris0211 is offline
Default Engine Cleaning
Im trying to get my engine as good looking as i can, without having to paint. Anyone have any tips or cleaning products?
Old 08-10-2007, 11:06 AM
300exoh's Avatar
300exoh
300exoh is offline
Default RE: Engine Cleaning
Oven cleaner works about as good as anything I've tried. Just avoid your wiring and plastic parts and rinse it down really well afterwards. You may even want to cover your alternator and other electronics with a plastic bag as best you can.
Old 08-10-2007, 10:09 PM
jk240sx's Avatar
jk240sx
jk240sx is offline
i use Simple Green and a spray bottle of water and lot's of shop towels and time. wax on wax off.
Old 08-10-2007, 11:24 PM
02dakotakid's Avatar
02dakotakid
02dakotakid is offline
i work in the detail department at a car dealership in illinois. when we clean a car for the customer we leave the car running, open the hood and use a pressure washer to spray off the engine. if its really dirty we use a basic all purpose cleaner that we just spray on the engine. it works really well.
Old 08-11-2007, 12:39 AM
dapirate559's Avatar
dapirate559
dapirate559 is offline
simple green is the best way to go. engine degreaser doesnt really work and is more expensive than simple green.
Old 08-11-2007, 01:53 AM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
x3 on the simple green... once you have it sprayed down, take it to a car wash and hose it down with the engine degreser setting... it'll come out nice & clean. be careful not to get any open air/breather filters wet.
Old 08-11-2007, 04:07 AM
owns's Avatar
owns
owns is offline
Just spray the heck out of it with engine degreaser, let it soak for 5 minues, and then pressure wash. No need to cover the electronic. Repeat as many times as nescessary.
If you don't have a pressure washer, those coin operated spray places work fine.
Old 08-11-2007, 04:43 AM
Joel_MD's Avatar
Joel_MD
Joel_MD is offline
I have been cleaning dirty car engines for years. I warm up the engine a little if it's cold, or wait a half hour if it's hot. I will start under the vehicle, and spray Gumout Steam Premium degreaser around the oil pan, transmission, and base of the engine block. Then stand up and spray the degreaser from above on the firewall, brake master cylinder, and anywhere it's greasy. Let sit for 15 min, then hose off with a hose or pressure washer. Usually I will repeat with Simple Green, then start the engine and idle it awhile to dry it. The smell of the degreaser will usually linger for a day or two, but the results are fantastic.
Old 08-12-2007, 12:41 AM
f0x672's Avatar
f0x672
f0x672 is offline
+4 or 5 on the simple green
Quick Reply: Engine Cleaning
